Repeater offsets not working with 70CM xverter port
This is an old thread but I'm having the same issue. I can receive fine on 442.750 with +5 offset but when I key up the repeater to transmit no offset occurs and no transmit happens on 447.750. Also, when I try to enter the PL code of 100 for DTCSS there are other letters and numbers in the dialog line.
Using Flex 6500, SmartSDR for Mac, Q5 L432-28 transverter, common IF0 -
Let's look at what happens under the covers here.
When you are on 442.750, the radio is actually on 38.75Mhz (that is the IF frequency -- a 404Mhz difference). This is ok if you are using the transverter port, which I assume you are as the transverter port covers from 1.8Mhz to 54Mhz continuously at 10dbm power out.
Now, when you transmit, the radio actually transmits 5Mhz higher. By using a 2nd slice on the radio, do you see a carrier at 43.750Mhz which is where the radio is actually transmitting? You will have to put the radio into Full Duplex (FDX).
Also, make sure that your Transverter can handle the huge difference between 432Mhz and 447Mhz. That is a 15 MHz band spread. I asked Corey about it one day and he said it can be customized to do that, but you have to ask him when you order it.
Screenshots of your Repeater settings are also very helpful in diagnosing what you are seeing.
Let us know what you find out.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
