TGXL stuck on "connecting" all of a sudden
I can't think of any change I made.... all off a sudden my TGXL just shows "connecting". PGXL and antenna genius on the same router/vlan and switch are fine. Same on all three of my computers. If I go to the basement and Physically touch the unit it operates fine. I removed the DC Power and plugged it back in with no change. As you can see I disabled windows firewall and this is all LAN stuff.... no internet/firewall/ports involved.
I've opened a ticket but figured I'd throw it out here since it's the weekend.
Thanks !
Josh - N0EG
Try doing a reset. You’ll need to reconfigure the tuner.
Turn the rear power switch off. Hold the Operate/Bypass button in while turning on the rear power switch. Continue to hold the button until the front panel shows Config Reset.
Reconfigure your settings.
Yea... Sorry... I should have stated I tried that already. Thansk Dave
Can you Ping the TGXL at the IP address on the screen?
It will tell you if you have a network connection to the device.
If you can, check the lights on the switch just to see if you have a physical link to the TGXL from the switch.
Does it work if it is not on a VLAN (just as a test)?
Hi Mike,
Thanks for responding.
Yes, my TGXL, AG and PGXL (in the basement all on the same unmanaged switch) are all pingable. This issue is only impacting the TGXL.
And, I apologize, I should not have even mentioned VLAN as I don't have any of that set up on my Ubiquiti network.... very simple lan/wan... nothing weird
Thanks again,
Josh - N0EG
Strange. It might be time to reach out to 4O3A about the issue.
support@4o3a.com
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
