TGXL stuck on "connecting" all of a sudden
N0EG
N0EG Member ✭✭
edited January 2023 in Tuner Genius XL
I can't think of any change I made.... all off a sudden my TGXL just shows "connecting". PGXL and antenna genius on the same router/vlan and switch are fine.  Same on all three of my computers.  If I go to the basement and Physically touch the unit it operates fine.  I removed the DC Power and plugged it back in with no change.  As you can see I disabled windows firewall and this is all LAN stuff.... no internet/firewall/ports involved.
I've opened a ticket but figured I'd throw it out here since it's the weekend.
Thanks !
Josh - N0EG
  • David Decoons, wo2x
    Try doing a reset. You’ll need to reconfigure the tuner.
    Turn the rear power switch off. Hold the Operate/Bypass button in while turning on the rear power switch. Continue to hold the button until the front panel shows Config Reset.
    Reconfigure your settings.
  • N0EG
    N0EG Member ✭✭
    Yea... Sorry... I should have stated I tried that already. Thansk Dave
    Can you Ping the TGXL at the IP address on the screen?
    It will tell you if you have a network connection to the device.
    If you can, check the lights on the switch just to see if you have a physical link to the TGXL from the switch.
    Does it work if it is not on a VLAN (just as a test)?
  • N0EG
    N0EG Member ✭✭
    Hi Mike,
    Thanks for responding.
    Yes, my TGXL, AG and PGXL (in the basement all on the same unmanaged switch) are all pingable. This issue is only impacting the TGXL.
    And, I apologize, I should not have even mentioned VLAN as I don't have any of that set up on my Ubiquiti network.... very simple lan/wan... nothing weird
    Thanks again,
    Josh - N0EG
    Strange. It might be time to reach out to 4O3A about the issue.
    support@4o3a.com
