High SWR Detected by Firmware
Lately I'm getting occasional High SWR alerts, checked my antenna OK, and a few days ago I opened a ticket and it seem to be a software related issue rather than a real SWR. I'm using a 6600 with a PGXL both software/firmware up to date as well as SmartSDR up to date as well. There is nothing in between the 6600 and the PGXL but a 3' new RG-213 coax.
After the ticket with support they recommend to operate the PGXL with Contest mode fan and MEFFA off and on the SmartSDR Settings / Radio Setup / TX Delay 30, instead of 20 and MEFFA on and Standard fan.
Everything seem to be working better after those settings recommendations...
But today I just got a High SWR Detected by Firmware (a different message than before) from the PGXL and I review the Usage Chart from the PGXL software and SWR 1.1:1
Has anyone experience this issues ?
Best Answers
Hi Juan
Try the new firmware and utility released today for the amp.
Hi Dave HNY !
Thank you and sure enough I immediately did the PGXL firmware update and it went fast and well, so far so good.
Juan TG9AJR
Well, after a couple of days of not using the 6600/PGXL today I tested and made a CQ and immediately I go the HIGH SWR Detected by Firmware (red alert), tried 2-3 times more with the same result. Then on another CQ it nothing OK and not alert...
Hi Juan,
This is a known bug and there will be an upcoming firmware upgrade for the amp to address the issue. It is in final testing. I cannot speculate the exact release date but soon.
Hi Dave, thank you for your answer and some hope for that... fingers crossed that will not take that long... is becoming more often and frustrating.
I just copied N5WS on 6m and called him back and sure enough HIGH SWR Detected by Firmware, now I'm at TX Delay 35 but still, so it's intermittent and was not happening before just until maybe 2 weeks ago.
For now, try increasing TX delay to 50 or 60.
73 & thanks for the Qi’s!
Thanks Dave I will keep increasing the TX Delay.
What should be the maximum TX Delay time ?
Happy Holidays 73
Yesterday I had to go from TX Delay of 50 which was working fine to TX Delay 60.
I hope I don't have to keep increasing the TX Delay time...
Yeah Juan having the same issues here,, for some reason 3.33 made it worse.. I downgraded to my previous one 3.2.39 and its more stable now but there was for sure something that drove the amplifier crazy on the 3.33 it happenned on both 6600 with two different pgxls1
Hola Felipe, OK understood and thank you for the information.
Is sad to see this "issue" remains a secret mystery, hope we all get a some fix sooner rather than later...
It's becoming VERY recurrent and annoying. Not to mentioned nothing officially heard about it. TX Delay keeps going up.
Opening a new ticket with help desk, to see if there is something,
Juan
Increased TX Delays may not resolve your issue.
There are a few issues here. The first is that the PGXL is very very good at detecting transients that happen in your antenna system, sometimes as fast as 10-20uS. These are events that no other device can detect in the amateur market. This is there to protect the amplifier.
There are also a few other things that may resolve this, such as the latest firmware that is about to be released. And, you may need to get support to look into things on your PGXL and for that you will need to open a support ticket. However, I would wait until next week.
I will mention your issue to our Support Director, N7HQ to see if he has an idea.
73 es HNY
HNY Mike and thank you.
OK and sure enough I did open a second time two days ago and still open.
So looking forward for this firmware update.
Hope N7HQ might have an idea about this issue.
TU 73
Correction: "OK and sure enough I did open a second ticket two days ago and still open."
We are on limited staff this week, so it will take some time before they get back to you.
Thanks Mike, in fact Ken NM9P answered but we are going to wait as I'm getting a dummy load (a must that I didn't have) to run some test. So ticket is solved (hold) for now until I get that test done. Also and just in case getting a new coax run "just in case"...
HNY
Hi Juan,
I had this problem with my 6600 and PGXL. I worked through the problem with Ken via the help desk. After many attempts at adjusting my setup including the fixes suggested above, a return authorization was issued for the PGXL. The problem was confirmed by the repair tech. A defective board was replaced. The new board was said to have solved the problem and the PGXL was returned. I will have an opportunity to test the PGXL when I return to my home station later in January.
I hope you are able to find a solution without returning your unit.
Larry, K4KGG
Thanks Larry, hope your PGXL returns working properly.
Thanks for the information.
HNY 73
I am getting the same error PGXL High SWR Detected by Hardware. Please stop Transmission.
This is only happening on 160 band, all others are fine, and I can use the same antenna on other bands (as the SWR is low) or a dummy load and it works fine.
This is only happening on 160 with an antenna, or a dummy load.
73 Jeff WB4TT
@Jeff WB4TT then it seems easier and just check your 160m antenna, maybe a loose contact or soldering point. In my case it was one loose feed point of my 6m antenna. I also end up with 30ms TX Delay on the SmartSDR settings, hope it helps, GL.
73 Juan TG9AJR
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 141 Contesting
- 985 Third-Party Software
