6600 Unexpected Shutdown
I have a 6600, running with a windows 10 pc. Here’s my problem. On various bands where the SWR is less then 2:1, the radio will intermittently shut down immediately upon keying. So wondering if this is likely an RFI in the shack issue, a ground loop issue, or improper grounding? Would appreciate any ideas on how to start troubleshooting ?
73 PaulEckerw2eck
Paul,
Do you get one of these error codes?
Al / NN4ZZ
Hi Paul,
It is not likely to be a ground loop as they only tend to distort audio.
The most likely culprit is RFI. Try transmitting at low power into a dummy load to see if the problem persists. If not, it is probably RFI.
If you can determine that it is RF getting in somewhere, you need to know what is being affected. Does the radio itself shut off or does SmartSDR shut down?
If it is the radio, you need to answer Al's question, above.
If it is SmartSDR, then the RF is probably getting into your computer. Start by disconnecting as much as possible from your computer until the problem goes away. The last thing removed is the most likely candidate. In my case, it was getting in on the USB lines. I had to put ferrites on the lines in and out of my USB hubs.
Paul,
If you suspect RFI, Grounding, or voltage problems I have some details on my web page about these issues and solutions. Just scroll down a bit and look at the links on my web page. But the radio error codes are a good start.
http://www.nn4zz.com/Flex6600.htm
Al / NN4ZZ
About 90% of our support calls are related to voltage drop/brownout when the radio shuts down in TX. It is the first thing you want to check.
There are various ways to test this, but with the Radio set to a 100% tune carrier into a dummy load and you hit TX, then you have a voltage brownout. This can be caused by corrosion on the Power Pole connectors and the simple fact of plugging and unplugging them a few times will clean off the corrosion. It doesn't take much corrosion to cause 1 ohm of resistance.
Another way to test this is to us FRStack to monitor the voltage in the radio, put the radio into TX with the tune power at 1% and then slowly increase the tuner percentage and see if the FRStack voltage reading starts to drop.
I had this happen to me last week. My full load TX voltage was down to 10.4V. When I did the power pole exercise 4 or 5 times, my full load TX voltage is now 13.8V down from 13.9V in RX.
This is the first place I would look.
Thanks for the suggestion. I did the TX tune test and at 100% tune power, the voltage is down to 11.24 fm 13.48v. So although the 6600 did not shut down due to a brown out, I am experiencing a drop. So if you are only seeing a .1 drop and I have a 2.24 drop, I do have an issue that should be fixed, albeit it doesn't appear to be the cause of the radio shutting down.
Tnx for the help
73 Paul w2eck
Al- thanks for help
1) No, I did not notice the error code, Most times when the shutdown occurred, I was too ticked to think of noticing the error code. Thanks for the idea, I will note it at the next shutdown.
2) thank you for the link to your page for RFI, etc. problems and solutions
Len- also thanks for your help.
1) the radio is shutting down, not SSDR
So my next step is to take note of the Error code and I will post what I find.
tnx & 73
Paul w2eck
If I recall correctly, the voltage spec is 13.8V +/- 15%.
If that is correct then 13.8v*0.85=11.73V.
Your measurement of 11.24 is less than 11.73.
Hi Paul, I think Mike diagnosed it correctly. The 2.24 V drop might not cause the rig to shut down every time, but is almost certainly the culprit.
I would work on that issue first. Your 13.48 V is a little low. I adjusted my power supply to 14.2 V. Others have suggested closer to 15.
Gentlemen
I took off the 24'' long DC cable running from the 6600 to Astron VS-35M. Cleaned power poles with Deoxit and then plugged in and out a few times as Mike suggested. Increased voltage to the radio 14.1v. Then ran Tx into dummy load. At 100% power, I am seeing a voltage drop of 1.72v, from14.1v to 12.38v. So an improvement over the previous 2.24 drop, but...
So If Mike is only seeing a drop of .1v on Tx, then I still have an issue. Suggestions?? other then make a new dc cable, new power poles, larger gauge wire. What gauge ore you guys using?
73 Paul w2eck
Hi Paul, the fuse is often responsible for a voltage drop. Take the fuse out and give it the same treatment as the connectors.
Paul,
One of the places that can result in a significant power drop is the internal fuse.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6600 Win10 Pro V2004 -- SSDR V3.3.33
Took the fuse out of DC power **** and cleaned with no appreciable difference in the voltage drop. So I see now you meant the radio's internal fuse. So is that just a case of remove cover off radio and fuse is accessible?
73 Paul w2eck
Just read section 7.1.1 in Hardware manual on fuse location and type. So cleaning it will be my next project. If no change after that will make a new cable.
73 Paul w2eck
Gentlemen
Just had the shutdown occur again and the error code is 2 flashes = software crash and in fact the radio does reboot after 15 secs. So my error in previously saying "1) the radio is shutting down, not SSDR"
So it would appear next step is to hunt down the RFI that is getting onto PC ? and solve that problem.
tnx again Paul w2eck
The software in the message refers to the software internal to the radio, not to SmartSDR.
I would submit a help desk ticket at this point.
Hi Paul,
The software crash could be related to low voltage. A help desk ticket is fine but it is still a good idea to check/clean the fuse. Also if you have a DVM you could also check all 3 voltage points to determine if you have a voltage problem and where it is.
I have some notes on that here:
http://www.nn4zz.com/Flex6600.htm#Astron_Power_Supply
Regards, Al / NN4ZZ
Al & Len
Will follow both suggestions - thank you again. Will keep you posted.
73 Paul w2eck
Yea keep track of your Voltages when you measure them so you can give them to the help Desk if it goes that far actually it's always a good idea to keep track of your voltages and tempratures and there locations anyway.
K9DUR has fine software for the Flex Radios and he has a very small nice little program that shows your voltage It does NOT however show the PA Voltage but doesn't have all the extra bagage of FRStack, here is the link to it.
https://k9dur.us/downloads/SDRMonitor/SDRMonitorSetup.exe
73's
Bret
WX7Y
Bret
thanks for the suggestions
73 Paul w2eck
Hi Paul... just throwing my $0.02 -- I found one measurement that was helpful to both me and the HelpDesk was to use software like FRStack to show you the 'internal voltage' within the radio itself. This eliminates (from a troubleshooting POV) the resistance/loss in the cable between the power supply and the radio, and any losses at the powerpole jacks.
FRStack is free (AFAIK) and easy to install and gives you all kinds of other neat monitoring features as well.
2nd the comment about taking the cover off and checking the contacts on the internal fuse (30A in my 6500 -- yours may be different). Cleaning mine off with an emery board made a significant difference (albeit it had been 7 years at least since mine had been opened -- it needed a good cleaning :-))
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
