STREAM DECK AND FLEX RADIO
Hello to all,
For the purpose of quick browsing, I became the owner of the new Stream deck MK.2. (15 keys).
Can someone explain and explain to me how I define the keys to work in Smart SDR?
I’ve looked at a few shots on YT before, but I haven’t spotted exactly how to set the keys anywhere.
Best 73, Dare S58M
Welcome!
  • Member, Super Elmer Moderator
    You can load FRStack from FRStack - My ASP.NET Application (mkcmsoftware.com)
    Then you need to install the latest Stream Deck software from Stream Deck | elgato.com
    In the Stream Deck software you need to install the REST plug-in located in the FRStack3 folder on your PC after the FRStack software is installed. The plugin name is com.mkcmsoftware.restcall.streamDeckPlugin
    You can double click the plugin file to install it.
    Then you can import the example profile located in the same FRStack3 folder. It is named FRStack3 Rest.streamDeckProfile
    That will give you examples already programmed for the Stream Deck.
    More info by running FRStack and clicking Help then REST Help.
  • Member ✭✭
    Hello Dave!
    Thanks for answer.
    Yes, i do it, but i dont know how configure keys. For example: on the board i see SET RX ANT1. What i must do, that this key will be in function and operate with SSDR?
    73 Dare S58M
  • Member ✭✭✭✭
    Under the FRStack "Help" pull-down (top far right) is "REST Help". This file has a list of all of the available REST commands.
    Look at the already configured buttons in the sample FRStack Profile. Use the profile buttons as a guide to understanding how to make new buttons, with the commands you like (easy to copy and paste the button to a new position and then make the minor changes for the command you desire.
    Alan. WA9WUd
  • Member ✭✭
    Does FRStack3.Rest.streamDeckProfile do anything or example only?
  • Member ✭✭✭✭
    Yes, the FRStack StreamDeck profiles are fully functional.
    Alan. WA9WUD
  • Member ✭✭
    I have Stream Deck+ ...will nice when Rest Call could be updated for new capability of StreamDeck+ - Dials, Touch screen...
  • Member
    I need a good setup for the 32 key Stream Deck. I saw one here recently when i visited before becoming a member.
    It all depends on what you are using the Stream Deck to control.
    In my case I have radio controls, PG XK, TG XL, rotor, AC outlets, DC relays, plus other functions (launching PC programs for example.
  • Member ✭✭✭✭
    edited March 2023
  • Member ✭✭
    I am trying to get Stream Deck to work. I did all the steps in Dave's post above:
    1) Loaded FRStack from FRStack - My ASP.NET Application (mkcmsoftware.com)
    2)I Installed the latest Stream Deck software from Stream Deck | elgato.com
    3) Installed the REST plug-in located in the FRStack3 folder on your PC after the FRStack software is installed. The plugin name is com.mkcmsoftware.restcall.streamDeckPlugin
    Now I start the FRStack3 application, and I get a message saying there are no radios available.
    The radio is on, SmartSDR has no problem finding the radio, not sure what to do next...
    Regards,
    Dave, N1AI
  • Member ✭✭
    edited March 2023
    Got past that by dorking with:
    Control Panel\System and Security\Windows Defender Firewall\Allowed apps
    And set the FRStack apps to "allowed".
    Now the FRStack3 app is finding the radio and showing the active slices:
    And the Stream Deck app is showing the profile loaded:
    EDIT: Stream Deck was totally dark at this point, but the fix was simple: the USB-C cable had wiggled out of the jack, LOL. Now it's lit up as it should be, buttons are showing their icons.
    Next, I did the stuff in Dave's u2b video StreamDeck integration with Node Red using web socket and FRStack REST commands - YouTube -- at minute 1:50 or so ( setting the "URI 1" field to "http://127.0.0.1:13522/api" ). Till I did this, nothing worked. Now it does. Not sure why this isn't in some of the various other setup web pages I'm reading, but this is what I needed to do to get it to work.
    Hope this info helps others...
    Glad you got it working!
  • Member ✭✭
    Hi all,
    I am also having trouble getting my Streamdeck + working.
    Any help greatly appreciated.
    I have a Flex 6500 on the same lan as my PC running Smart SDR 3.4.21.
    Radio and SmartSDR all work fine.
    PC is running Stack3 v 3.1.36.70 and works with the 6500 fine. (shows slice data. Spots work etc)
    Installed
    Stream Deck latest software v6.3.0.
    I clicked on the two files in FRstack and it seems to have installed Rest Call 1.2 and a FRstack profile which appears on the stream deck buttons.
    I set the Global URL 1 to http://localhost:13522
    But so far nothing seems to be working.
    Can you point me in the right direction please.
    M0MDS
  • Member ✭✭✭✭
    Just to summarize previous help in this thread:
    In Stream deck you see a parameter setup like below?
    You have FRStack running and it finds your radio?
    Stream Deck as well as FRStack have Firewall entries set to allow for all ports and protocols on all profiles (Domain, private, Public)?
    Let us know on these points.
  • Member ✭✭
    Does this work als on a 15 button Streamdeck, or do i not have all the buttons?
  • Member ✭✭✭✭
    A 32 button profile on a 15 button deck will only partially display (the top left corner 15 tabs in the profile).
    Therefore you would need to edit the 32 button profile and create a separate 15 button one. For this use the Lorby StreamDeck Editor and below you see a 15 button profile that I quickly created as a demonstration for this answer.
    Lorby is at https://www.axisandohs.com/uploads/6/0/8/2/60827113/lorbystreamdeckeditor_1_07_b11.zip
    Create an empty profile in StreamDeck. Use Lorby to load it. Also load the 32 button profile - you can populate the editor with whichever page you most want, probably the top page. Drag and drop to create your 15 buttons and save. SD must be closed to enable save. When you re-launch SD you will have your 15 button profile available.
