Smart SDR (Windows) Power Genius XL (PGXL) Meter SWR and Unresponsive
Brian_KF4IRE
Brian_KF4IRE Member ✭✭
edited October 2022 in Power Genius XL Amplifier
Earlier this week we slipped into the man cave/ham shack to tune up 6600M and reach out as we do several times a week. This evening I noticed the AMP window within the Smart SDR application 3.3.32 was inoperable. The PGXL amp however was working as normal. The PGXL utility working fine as well. Well, as per usual - reboot/cycle power every thing (one at a time though). Rebooting the amp corrected it - business as usual. Noticed the SWR meter on the Smart SDR PGXL meter window was back where it has been ever since 3.3.32 was installed... registering 1.25:1 --??-- Checked on line here and couldn't find an article using a number of search strings - saw there was an update to 3.3.33 so I went ahead and updated the radio and the Smart SDR for Windows.. - Cold started everything - rebooted and it was still there - Checked the release notes/changes/bug fixes - not even an honorable mention of the 'bug'.
So what is it? Wrong search string, the issue is addressed over here and here's the fix? Is it a problem that only I have? It's not really hurting anything other than I'll never be able to tune my antenna and see what the Amp is registering for an SWR if it's less than 1.25:1 because that's what it registers all the time unless its higher than that. Suggestions?
  • K5XH
    K5XH Member ✭✭✭
    Since upgrading to 2.8 I am seeing the same thing so it is not only on 3.x.x versions.
    Mark K5XH
  • RFord
    RFord Member ✭✭✭
    Brian this is a known issue...we were told it has been corrected and we should see it resolved the next update for the PGXL...hope this helps...
  • Brian_KF4IRE
    Thank you Gentlemen. It's refreshing to know that I'm not alone and that what I'm seeing isn't an individual user induced problem. If by any chance either of you can recall where this is addressed or discussed or even how its described it might help me better understand how things are described so I can more easily find answers to my own questions without posting repeat articles.
    Thanks again...
    Brian
    KF4IRE
  • David Decoons, wo2x
    Yes, Flex is working on a firmware update for the PG XL which corrects this issue.
  • Danny78
    Danny78 Member
    Hello,
    I have just bought the AMP(3.6.24 and Tuner(1.1.8) so brand new user.
    Do you all have the SWR in SmartSDR/Power Genius XL area indicating 1,25:1 even in RX? That is the situation here with 2.8.1 SmartSDR version.
    When i installed the AMP and Tuner Genius I had v2.7.6 on the Flex 6700. Everything was fine while testing. Later the day I updated all my software and when testing again I had the SWR indicating 1,25:1 all the time even with no TX?! First I thought it was a software problem and rebooting everything but it is still there so I searched and found this article.
    If it is a known bug and someone is working on it that's OK for me.
    Best regards,
    Danny
    This is a known issue which will be corrected.
  • KM4CQG
    KM4CQG Member ✭✭
    Reload the Firmware will temp Fix the issue
