PGXL DHCP 'JITTERS'
After installing a new router using a different IP, I observe the PGXL IP address field displays a strange character, and the [DHCP-IDLE] is jittering (for lack of a better term) The PGXL works as it should otherwise. If I switch back to the old router, the PGXL displays the IP address as expected. While it's certainly not a showstopper at this point, I'm wondering how to correct this condition. Have tried reboots. Thanks for your time!
Welcome!
  • Member ✭✭✭✭
    Was/is the PG-XL configured to use a static IP address? If so, and if the new router is set for a different sub-net, the two will pass in the wind and not connect.
    Suggest you endure the PG-XL TCP configuration is set to use DHCP, and not static. Then, try again with the new router.
    Alan. WA9WUD
  • Member ✭✭
    Thanks Alan,
    The PG-XL is set for DHCP. When I open the PG-XL utility it shows the correct IP. Only the IP display on the amplifier screen shows no IP address, and instead just flickers.
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    Paul, what version of the software/firmware are you using?
  • Member
    I am experiencing same thing, just received PG-XL yesterday. Firmware version is 3.6.24.
    Tried it DHCP and Static (same IP number as a reservation in the router). It is connected to a GB switch off the main router as is the 6600 and TG-XL. Software shows IP correctly, operates correctly, just that the PG-XL flickers 1 or 2 symbols for the IP address. Have not tried connecting it to the main router (will need longer Cat6 cable to try it.)
    As a test, can you run a simple test and run it through a 100mb/sec switch?
    I'm starting to see that 1G switches are not all made equal.
  • Member ✭✭
    Hi Mike,
    v3.6.24 on 1G switch
  • Member, Super Elmer Moderator
    Hi Paul,
    You mentioned reboots. Have you tried a reset to defaults? Turn the rear power switch off and then hold the Op/Stby button while turning the rear switch on.
    Once it resets you will need to recalibrate the touch screen by touching the blue dot in three places.
  • Member ✭✭
    Hi Dave,
    Gave that a try, still jitters.
    I created a support ticket for you
