Why does the TGXL need a PTT?
I have wondered why a PTT is needed for the TGXL. Since the device knows the frequency, has in memory the appropriate settings and has plenty of time to set them after a band change, what is the purpose of the PTT signal here:
Just curious really doesn't matter in operation.
Peter
Hi Peter, I don't have a TGXL, but my KAT500 tuner takes PTT in from the radio and passes it on to the amp. If the SWR is ok, it passes the PTT signal to the amp. If not, it alarms and keeps the amp from keying up.
I would think that the TGXL does something very similar to that.
Peter, I would do this:
Foot or Hand switch to the TGXL In PTT
TGXL PTT Out to PGXL PTT IN
PGXL PTT OUT to Radio PTT (Icom calls is Send I think)
That way, you key the TGXL first, then the PGXL and then the Exciter.
Mike thanks. However the challenge is to use FT8 etc. The software sends the PTT. Timing is key so a foot switch is a ok for CW or SSB but I can’t incision that working with FT8.
what do you think
Peter
A simple answer,
The reason for the needing the PTT is because the PTT line is the only way on a NON Flex radio to tell the tuner logic which transmitter to switch to on Radio / Antenna port A or B.
One of these days the firmware will hopefully be there for the TGXL and THE PGXL to understand RS-232, Icom and TCP/IP CAT information from various Radios or software which as everyone know the radio understands from the PTT command from todays Sound Card type software and should be able to be used to talk to the AMP more then just Frequency. I have already put my request in to 4O3A for this feature.
Sorry that’s not quite enough. If both port’s know what frequency they are tuned to there is no need for a PTT line. The signal should pass through the tuner. Both ports can be used simultaneously can they not?
Peter
You only have one tuner in the TGXL that switches between the two ports.
Ag ha.
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 864 Genius Products
- 306 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
