DAX Reserved channels
You cannot disable them. Unfortunately, we do not know of a way to keep Windows from showing them either.
Ultimately, we could eliminate them entirely, but it is a significant investment to do so (it involves moving all of our DAX UDP code into a kernel mode driver). The payoff is a cleaner looking system, but other than that, there's no benefit. We discussed doing this at the outset, but it would have pushed out things like waterfall, etc. that are next on the list. It was unanimous in our company to take the faster approach and focus on delivering more important radio features rather than take on another kernel mode driver project ;-) Having said this, I think those of you that have used it will agree that it far surpasses running a sound card, cables, serial for PTT, etc. in terms of simplicity, flexibility and performance.
If I have my way, you guys are going to get tired of hearing me say this: sound cards are a compromise method for connecting to a digital radio. The best way is for the digital mode program to directly consume UDP streaming data. It avoids a classic two-clocks problem, eliminates latency, get's rid of meddling Windows resampling, etc. I do everything I can to encourage folks that write digital mode programs to connect directly to us if possible. I understand this is a "single radio" solution, but we have adopted the VITA-49 standard to make this a winning prospect for the digital mode program author -- hopefully over time other vendors will also support this standard for delivery of radio IF data.2 -
I agree and thanks Steve. The reserved channels just get in the way and make it difficult, if not impossible with some software, to match up the correct RX and TX pair.
I love DX Labs...great software and he will be supporting the 6xxx radios more as time goes on. But he has a limit as to the number of devices that can be shown and too many of them end up being IQ or Reserved channels.1 -
Steve,
In the short term, maybe a name change would help avoid picking a reserved channel by accident or disabling it by accident. See snapshot with a suggestion for the wording.
We can do this ourselves from the "properties" dialog (right click on the device), but it might be nice for consistency to have it set up that way from the start for everyone.
It's a minor change but might help avoid some confusion and trouble tickets.....
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
If you change the name, DAX will not work. It finds the sound cards by their name. We spent 20 minutes talking about how to name these and get them to show up in most of the programs (many of which truncate length, etc) and I wish I could get THOSE 20 minutes back (never mind spending another 20). We really hoped that the word RESERVED along with the explanation in the manual would be enough to help folks understand that this is the side you keep away from (don't connect to it). It really seems like a pretty simple rule to me. There were lots of suggestions like "DAX DONT TOUCH" and the like, but we felt that RESERVED was reasonably professional and explanatory at the same time.
Now we also have detail here to help people find the right side, too.
At the risk of opening old wounds... perhaps INTERNAL would express the same sentiment? But then again, I think EDUCATION for the users is the best approach! "A little learnin' prevents a whole lotta hurtin'..." Keep on teaching us! Thanks....-1
but after 7 years should this issue not be solved ?
Andy K3UK
Andy
I think Steve, the CTO, outlined the reasons the way it is. It really isn't broken, it is just the way it has to work in Windows.
What is it you would like to see and I will pass it on for you.
Just remember that RESERVED means Reserved for the radio, and not available to the software programs.
RESERVED DAX are the “radio end” of the virtual audio cable.
likewise with CAT.... the CAT ports are created in pairs.... com 5/105.
the port 105 is the “radio end” of the virtual serial cable.
(all cables have two ends — the “radio end” and the “outside world” end.)
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
