N1MM via IP Addressing -- dump the com port
If you are TCP/IP savy, you might want to give this a try for N1MM.
The Port numbers for each function must match the port number CAT and they must all be unique and not used by some other process.
Thanks to the N1MM team for moving to Raw Sockets and allowing us to move away from RS232.
edit: I removed OTRSP and WinKeyer for TCP as I was not able to get it to function.
60000 is for Slice A CAT
60001 is for Slice B CAT
and, I used 2334 is for the Cluster Spots from N1MM and they are sent to the Radio.
Thanks Mike, will ty these settings in the contest.
Thanks for sharing this Mike. Very useful.
Val
DM1TX/ DL1X
The OTRSP port still needs to remain a serial COM port in current version of N1MM+
Same with Winkeyer.
You might be correct. I'll open a ticket with N1MM.
Any feedback from N1MM? I seem to have OTRSP working with a TCP port but Winkeyer is still a COM port.
This is using N1MM version 1.0.9705.0.
Chuck W9WLX
I don't think the Winkeyer is supported at this time. I'll edit my posting.
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 264 FLEX-8000 Signature Series
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
