New headset problem
Now, when I transmit, the RF Pwr meter barely moves. My headset is the default device on my PC, the microphone levels are maxed out on windows, RF Power is at 100, and I've turned the gain up all the way in SSDR. Am I missing something? Is my radio messed up? Any help is greatly appreciated.
-Cody K4LTC
Hi Cody.. have you tried the +20db mike boost on the Settings/Radio tab?
Yeah, I've tried just about everything. I've also tried out a few different headsets. Same thing. The only other thing I can think of doing is to buy a USB preamp and try it.0 -
Hmmmm... if different headsets are causing the same symptoms, then it definitely points to something in the radio. What about turning on the bias setting (same place)? Some mics need power applied to the elements to make it work.
When the radio is working, there is MORE than enough ooomph to let most mics work.
Something else I found (from discussions with the Help Desk) is that the current version of SmartSDR NEEDS the processor turned on to effectively drive the PA. You can just leave it on NORM, but maybe try that.
If he's connecting the mic to the PC, bias setting on the radio will have no effect.
I have had this problem when using ext sound card /usb headsets. Don't know if it's a Pwrsdr issue or windows but this is my work around:
I use the transmit graphic equalizer as a way to add mic gain . Instead of having all the sliders start at zero, set them all at say +7 across the whole range. This will give you a +7 db boost to the transmit audio. Now you can add or subtract up to 3 db on each slider for EQ. This does limit your range of eq to +/- 3db but may be enough gain boost/eq to help you out. If you don't care about eq you could set them all to +10 which will give even more boost.
Jerry
W1JWC
@Geoff... yea, missed that. You're right.
@Cody... Is there any way you can either a) connect the headset directly to the PC w/ the USB thingee? or b) connect the headset directly to the 6600 via the mic jack? -- just to check that the radio/headset are working correctly.
@VE7ATJ_Don I know the radio is working as it should because I can use my old broken headset through my PC and everything is fine. I've just had this old headset for so long one of the earpieces broke off. It seems like every other headset I've tried doesn't have enough oomph to get more than say, 5 watts of RF out. The new headset I bought works on things like Discord and other voice apps.
I think I'm gonna try out the usb preamp. If that doesn't work, I'll be back to these forums asking for headset recommendations!0 -
OK,,, sounds good. Because the 'old' one works (I'm assuming without the USB dongle), then maybe a new headset would be something to try.
With the 'new' headsets, what's showing up on the LEvel and Compression meters on the P/CW tab? Are they moving with your voice? What's the Mic Gain set to?
Me, I use boom headsets from SteelSeries and they seem to work fine for me -- either plugged directly into the radio or plugged into the USB port on the PC.
I looked into getting a headset from SteelSeries but bought one from Razer instead. Needless to say, I had the same problem with it. Which model SteelSeries did you get? Do you get good audio reports with it? Maybe I can try it out if the usb preamp doesn't work.0
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 39 Aurora
- 947 Maestro
- 924 Genius Products
