SO2R Contest recording in Dxlog
ik2egl
ik2egl Member ✭✭
Morning
Running so2r and dxlog software I need to record audio from both receiver, A and B slice, both together.
Recoding can be done using Dax but it works only for one slice, (ie Dax 1, slice A) and I do not know how mix the two slice together
Any idea?
Don IK2EGL, AD2DC
    I would use VB-Audio Banana (yes, that is the name)
    And, assign Slice A to DAX 1 and Slice B to DAX 2.
    You can then mix them in the virtual mixer and record it to the built in recorder. It works very well.
    It takes some time to set up, but well worth the effort.
  • ik2egl
    ik2egl Member ✭✭
    Tnx, will try
  • ik2egl
    ik2egl Member ✭✭
    Morning Mike
    could you give me some more details on your BANANA configuration ?
    It would help me ,
    thanks
    Don
  • va3ar
    va3ar Member
    Hi Mike,
    Recording works fine, thank you.
    Any idea how to record the sent CW tone in the same time?
    Stefan
    va3ar
