how to "reset B"
During hurricane Ian I was monitoring both Hurricane Watch Nets on 20 and 40m. It was really neat to be able to have VFO-A on 20m with AG selecting my 20m beam, while VFO-B was tuned to 40 and AG selecting the 40m beam. Worked like a champ.
Thankfully Ian passed and I wanted to go back to "normal" operating where most of the time I'm just using VFO-A, so I deleted the slice containing VFO-B and the 40m tuning. To my surprise, the Antenna Genius software stills shows B as selecting the 40m beam, even though there is no VFO-B in SmartSDR.
What's worse, switching VFO-A to 40 meters results in no signal because AG has locked A out of 40m because it thinks B still has it!
I've been able to reproduce this:
- Tune VFO-A to 20m (or any band). Notice AG has selected the right antenna for A.
- Create a 2nd VFO and change its band. Set the xmit and recv antenna to #2. Notice AG has selected the right antenna for B.
- Delete VFO-B. AG's display does not change.
- Change VFO-A to the same band you set on VFO-B. AG will show A is locked out because B still has it.
The only way I can reset or clear AG is to go to settings, configure device, and click the "reboot device" button at the bottom. After that AG shows no antenna selected for B and A works just fine.
What am I doing wrong?
Brian n8wrl
In the AG setup for each antenna port, do you have None selected? If so, unselect None and just select the proper bands for each port.
Dave, you are a genius! That "fixed" it!
I use "air quotes" because I still think that's a bug - the VFO is gone so its lock on the antenna should be too. But I'm back in business, so I'll take it!
Thanks, and 73!
-Brian n8wrl
Glad it worked out.
I believe the None selection is designed for use with radios that cannot communicate with the AG.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
