No slice receiver on start ?
Previously when opening SSDR, it would open with one slice receiver, one panadapter- or how ever many I had open upon shutdown. Now when I start SSDR, it opens the slice(s) with no slice receiver(s). This just start a few days ago. Anyone have a tip on how to correct this problem?
73 Paul w2eck
Hi Paul, assuming that you shut down the rig using the power button (or remote-on jack), then you might want to export your profiles, do a factory reset, and re-import your profiles.
If you are powering down the rig by shutting down the power supply, you might want to start using the power button for a graceful shutdown before removing power.
Len
No I am not shutting down rig with the power supply, I use a remote wifi switch with and the remote on jack. Still searching for reason, but will consider the Factory Rest
Thanks for the help
73 Paul
A screen shot of what you are seeing will really help diagnose your problem as there are a few things it might be.
If it is what I think it is, something is blocking the VITA49 streaming data from the radio to your client. I doubt that rebooting will resolve your issue. Based on your comments, this is a SmartLink connection?
If rebooting doesn't resolve it, then please open a support ticket and provide some details on the client you are using, the version of SmartSDR, the Radio model and if you are local or remote. Also, is any part of this connection on WiFi?
I had a similar problem a few months ago. A factory reset fixed it. I had been tuning around below the broadcast band with no issues. But, turned the radio on the next day and had the same issue you are having. I did a reset and the problem went away. And I still play around with listening to beacons without any problems. I guess Windows (on my 6600M ) didn't like me exploring!
Good luck/
To answer Mike -
Not much to see in screen shot, just SSDR opening without a Slice Receiver. Connection is not Smart Link and am not using WiFi in any way. I have rebooted several times with no change to the issue.
James - yours is second recommendation for Factory Reset. But first I think I may take Mike's recommendation open Support Ticket and see if we can figure out what caused the problem.
73 Paul w2eck
Hi Paul,
did you get a solution to this? Just started up my radio this morning to the same issue. No slice receiver and a 'greyed out' add slice receiver button, so no way of adding a receiver slice?
Thanks in advance.
Rich MW0XDT
Hi paul
Same issue here on power up this morning on 6700
Factory reset did not cure the issue.
I'm opening ticket
Good Luck Neil
G0GGG
Hi Paul
It looks like a software issue Flex working on soluttion SmartSDR Outage - September 27, 2022 — FlexRadio Community
Lets hope it released quickly 6700 dead in the water here
Neil
Unfortunately, I am in the same boat with my 6700 today.
It was fine yesterday, and I made a lot of 10 M contacts.
Today, I found that all my slices were gone. I disconnected the power and factory rebooted many times without a change.
I hope that this SSDR/firmware fix is released this week.
Good luck to the rest of you out there!
VY 73,
Roy AC2GS
Yes, I installed the new firmware and everything is back to normal once again!
Vy 73,
Roy AC2GS
- 370 Community Topics
- 628 The Flea Market
- 87 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 781 Peripherals & Station Integration
- 996 Third-Party Software
