Antenna Genius only follows one Rig correctly
Yes Port A on antenna Genius is assigned to rig One by Rig Serial #
Yes Port B on antenna Genius is assigned to rig Two by Rig Serial #
But, Antenna Genius only follows Band change on rig Two to the correct antenna (always)
Not so with Rig One. (Some times it does most often it will not)
Any hints as to why this happens
The user of Rig One Port A
Is remote user
Often necessitating station owner where both rigs are to manually force the antenna genius to the right antenna with a mouse click on the antenna genius software
Steve KG5VK
Hi Steve
make sure the antenna selection in the AG app config for radio 1 matches the radio.
Example - if Radio 1 is set to ANT1 in the AG and Radio 2 is set to Ant2 then first radio must have RX and TX antenna set to ANT1 and second radio must have RX and TX antenna set to Ant2
Dave that is in fact always done...
I Do appreciate the feedback, However
Station procedure Rule for antennas is
Left Rig (considered rig 1) is Ant1 for rcv and xmt and even RCV only antenna is on Port A
Right rig (considered rig 2) is Ant2 for rcv and xmt and rcv only antennas is on Port B
I will note this only happens when the Remote Op is remoting into Rig one
No problems locally
And zero problems when I remote into Rig two
Steve KG5VK
I would suggest that you reach out to 4O3A (support@4O3A.com) and describe the situation to them. They are the manufacturer of the Antenna Genius.
Hi Steve
i have not seen that symptom when I had two Flex radios connected to one AG. Right now I only have one radio so unable to try and reproduce.
as Mike said, contact 4O3A.
In the meantime, you can reset the AG using the dip switches when powering it up (procedure in the manual) then re-enter antenna and radio settings in case something in AG memory is corrupt.
Email sent to 4O3A
awaiting reply
What Firmware version are you running ? This was an issue on 3.08 and one or 2 after it but was fixed, I believe in 3.13
Ron, WV4P
3.1.5 is latest, plus there was a slight update to 3.1.5 on 4O3A site.
I did contact 4O3A
They stated that a new firmware would be out within a few weeks making it more "Stable"
I was and I am still running version 3.1.5
If there was an update to that I have not seen it
However, Dave WO2X's comment implies that maybe there is a newer version of the same numeric firmware?
So maybe I should re-download?
I am also now running a MacBook Pro in addition to my Windows toolsets
The Mac is mainly used when I am on the road
I am running SmartSDR App for Mac by Marcus and seem to have some Antenna Genius issues there as well
So my struggle to once again love the Antenna Genius Tool continues
73 Steve KG5VK
you Might try downloading the 3.1.5 utility and install it over the top of what you already have then upgrade the firmware by browsing to the folder 3.1.5 installs to. Possible the first firmware upgrade to your swith didn’t go 100%
Double check dip switches 3&4 which set input type for radio 2.
You could try a reset too. Procedure is in the manual.
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
