6600 & WSJT-X Wide Graph Issue?
Woke up to a new issue with WSJT-X and its Wide Graph display. I appear to be receiving the signals fine on my 6600. The signals sound normal and look normal on the panadapter in SSDR. But in WSJT-X they are not being decoded and in the wide graph, instead of seeing the signals, I am seeing it blanked by red lines such as interference?
Other modes are working fine, for instance CWSkimmer is seeing and decoding signals normally. I am using SliceMasterto start WSJT-X. Checked the settings in WSJT-X and all appear as they should be. Changed antennas, no difference. Tried JTDX and am seeing no signals or decodes in it either? Any suggestions??
73 Paul w2eck
Dave
Started up and radio and WSJT-X client, checked all you points and voila, it's working. Not sure which one did the trick but thank you very much,
73 Paul w2eck
Hi Paul
Check the slice to ensure you have a DAX channel selected.
Next in DAX control panel make sure that DAX channel is enabled and blue. You should see receive level. For WSJT-X, I use a level of 34 on DAX RX.
In WSJT-X make sure in audio tab you have the proper DAX RX selected (DAX RX1 for example).
One more tip - DAX TX - I find a level of 48 in DAX control panel for TX and power slider in WAJT-X all the way up provides level right at zero without going over.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
