6600 & WSJT-X Wide Graph Issue?
Woke up to a new issue with WSJT-X and its Wide Graph display. I appear to be receiving the signals fine on my 6600. The signals sound normal and look normal on the panadapter in SSDR. But in WSJT-X they are not being decoded and in the wide graph, instead of seeing the signals, I am seeing it blanked by red lines such as interference?
Other modes are working fine, for instance CWSkimmer is seeing and decoding signals normally. I am using SliceMasterto start WSJT-X. Checked the settings in WSJT-X and all appear as they should be. Changed antennas, no difference. Tried JTDX and am seeing no signals or decodes in it either? Any suggestions??
73 Paul w2eck
  • W2ECK
    W2ECK ✭✭✭
    Answer ✓
    Dave
    Started up and radio and WSJT-X client, checked all you points and voila, it's working. Not sure which one did the trick but thank you very much,
    73 Paul w2eck
  • Hi Paul
    Check the slice to ensure you have a DAX channel selected.
    Next in DAX control panel make sure that DAX channel is enabled and blue. You should see receive level. For WSJT-X, I use a level of 34 on DAX RX.
    In WSJT-X make sure in audio tab you have the proper DAX RX selected (DAX RX1 for example).
    One more tip - DAX TX - I find a level of 48 in DAX control panel for TX and power slider in WAJT-X all the way up provides level right at zero without going over.
