3 minutes in the event of malfunction in the control link transmission limit.
Is there a method to meet the 3 minute rule requirement when operating Telecommand?
    Answer ✓
    I am not sure what the rule is.
    However, you can set a transmit time out timer. We call it PTT Timeout.
    It is outlined in section 33.6 of the SmartSDR UserGuide.
  • Rick_KJ5WO
    Rick_KJ5WO Member ✭✭
    Thanks Mike. Sorry for the newbie question. The FCC requires that if your running remote and you lose control that the radio can stop transmitting after 3 minutes. I'll give the PTT timeout a try.
    Thanks again.
    Here you go
    This means the radio will drop out of TX after the time you enter here. Regardless of a remote connection or not. So, if you are long-winded rag chews, your radio my decide you have been talking too long. :)
