PGXL & 6700
DonS
Member ✭✭✭
When I turn on the amp and leave it in standby everything works ok. Proper output, etc. As soon as I turn the amp to operate and press tune on the 6700, the radio goes into transmit, however, the SWR shows 3:1 on the radio and there is no output from the radio. If I go into a dummy load the same thing occurs. I am using a LP-100A following the amp. The TGXL is set to ANT 3 for the dummy load and ANT 1 for the beam. It doesn't make a difference on the setting for power output from the radio. Could there be an issue with the PGXL when it goes into transmit and is in the operate mode? The 6700 operates without an issue when the amp is in standby. Any thoughts?
Don - kx9q
I opened a support ticket for this.
Don
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
