6600 and Triplexer
ne9u
Member ✭
Is it safe to use a low power 200w triplexer with a 6600m without any additional external filters?
Or are the built in filters adequate?
You should be fine, but we need to know more about your station setup.
If you want to work on 20 and 15M at the same on a Tribander, you don't need a triplexor at all.
Scott,
I use the 6600 with a 500W triplexer and I don't use any external filtering. There is a worksheet available from Flex that will step you through measurements to make sure your particular setup is safe band to band.
73, Pat KØPC
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
