6600 and Triplexer
ne9u
Member ✭
Is it safe to use a low power 200w triplexer with a 6600m without any additional external filters?
Or are the built in filters adequate?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou should be fine, but we need to know more about your station setup.
If you want to work on 20 and 15M at the same on a Tribander, you don't need a triplexor at all.
Scott,
I use the 6600 with a 500W triplexer and I don't use any external filtering. There is a worksheet available from Flex that will step you through measurements to make sure your particular setup is safe band to band.
73, Pat KØPC
- 111 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
