Port fowarding
Troy NW1B
I had to install a new SD card in the 6400 and at the same time I was required to upgrade to 3.3.32
When I checked the smart link test I found that my settings needed to be reentered.
I but the same values in for TPC and UDP that I has used in the previous version but no luck.
Nothing changed in the router .
Previous version worked well.
Any ideas what I've forgotten to do?
Troy
I would walk through all the steps you did in Chapter 9 of the SmartSDR manual. You may have to do the PTT registration.
As long as you have uPNP turned on on your router and the automatic settings on the radio, it should be good to go.
If you get hung up, please open a support ticket and they will get it sorted out for you.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
