Port fowarding
Troy NW1B
I had to install a new SD card in the 6400 and at the same time I was required to upgrade to 3.3.32
When I checked the smart link test I found that my settings needed to be reentered.
I but the same values in for TPC and UDP that I has used in the previous version but no luck.
Nothing changed in the router .
Previous version worked well.
Any ideas what I've forgotten to do?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsTroy
I would walk through all the steps you did in Chapter 9 of the SmartSDR manual. You may have to do the PTT registration.
As long as you have uPNP turned on on your router and the automatic settings on the radio, it should be good to go.
If you get hung up, please open a support ticket and they will get it sorted out for you.
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
