How to upgrade a 6300 from 1.12
Best Answers
Terry,
It would be best if you open a support ticket just to see if you need to do it in stages.
https://helpdesk.flexradio.com
Here you go <-- click here
Just wish I could get a simple answer0
Sorry...I can't resist...Mike's suggestion seems pretty simple to me.
Just reading the mail here.
It just seems like every page I go to refers me some place else0
If you move to version 2 or 3 you will have to pay for the version upgrade UNLESS your radio qualifies for the version upgrade by a prevous purchase but ONLY support can run the radio serial number and see if it can go to a differant version without cost.
You should contact support just to make sure you can jump to the latest Versions here: https://helpdesk.flexradio.com/hc/en-us/
they are prety promp most of the time
Version 1.12.1 is the newest version of Smartsdr version 1.
So are you wanting to move up to version 2 or 3?
If so you will need to contact Flex to see what your 6300 is capable of handling. Once that is determined you will have to pay for the upgrade.
If you are ok with version 1 then don't do anything because you're already there.
Got it done, thanks for all the help-1
This is not directed to tc423239 only, it's only a suggestion that I think would close the loop for everyone...
I find that usually when someone finds a solution to a problem they state that the issue is resolved without detailing what was done.
In all situations I believe it would be helpful to others if the details, and steps necessary, to fix the problem were related as well.
That way if someone has the same problem they can have some idea where to look for a solution.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
