V3.3.32 CWX issues
Tried V3.3.32 CWX, the dot to dash spacing is not consistant. Dots can run together with dashes. Hand keying sound heavy and dfficult to craft a good sounding CW transmission.
Anyone seeing similar issues? Any suggestions?
Thanks;
Bill
Rebooted the radio and CWX is okay now. Radio has been on for over a week. Will file a report with the help desk.
Hi Bill, there is a known issue with CW. Are you operating remotely? Using a Maestro? Which radio are you running?
I find that when running CW remotely, I have to dial in some CW Delay. I most often operate remotely when I am up in the mountains with very poor cell service (using my phone as a WiFi hotspot). Last time out, I found inconsistent CW even with 80 ms of CW Delay. Once I moved it up to 100 ms, it cleared right up. I added another 50 ms just to be sure and have left it there ever since. Normally, at home I can run it at 30 ms or less.
You mention CWX. Are you typing CW into the CWX window? I don't operate that way, so I don't know if there is an issue with it or not.
How do you have your hand key connected? If you are using the accessory socket, try plugging into the key socket and set Iambic off. That might help.
Don’t understand the complaint. CWX issue or manual keying problem.
Len-
Thanks for the suggestions, as mentioned there was something wrong with the radio internal software. Rebooting the radio cleared the problem. Had some delay dialed in as well.
Typing into the CWX window sounded bad as well. The internal keyer was not operating properly.
I am running 6700 to a local PC with the key plugged into the front panel.
73;
Bill
This is "normal". After running for a few days cw turns into garbage. A software shut down and restart usually clears it up but sometimes the radio needs a restart. I'm not sure which revision this started in. There's also the playback problem which distorts the recorded audio and requires a restart. It's frustrating and even embarrassing at times. I guess Flex has bigger fish to fry as they say.
Thanks, we have this one documented as SMART-8513.
I've experienced this as well. When it happens, and club members hear it on the air, they start asking what's wrong. Explaining that this high $$ radio can't send CW reliably is quite embarrassing.0
I've experienced this as well. Embarrassing is the right word. I use my Ten-Tec for CW now.
Also I have noticed that the sidetone begins to slightly truncate the dit length after operating cw for a while. The actual transmission isn't truncated. The total "trashing" of the cw takes a day or two to show up, then it's reboot time. Apparently the bit bucket gets overfilled. 😒
BTW: I wonder if the audio recording problems are related to this?
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
