Running Smart SDR on one PC and HRD, WSJT on another PC
Greetings, I am a new owner of 6600 and I wonder if there is any sense in having Smart SDR, Dax, running on one PC and everything else - like HRD, WSJT, Amps control, Antenna control, running on another PC. Does anyone has an experience with such setup? Any positives or negatives? Any connection details? Thank you, Alex, WK1O
  • Bob K8RC
    Bob K8RC Member ✭✭✭
    I regularly do something like this. The main shack computer runs logging, WSJT and various power and antenna control programs and a copy of DAX. This computer and my 6600 are up some steep stairs on the 2nd floor of the housie.
    I run SmartSDR for iOS on an iPad and remote into the shack computer from a laptop from the comfort of my big leather chair downstairs (back porch on a nice day)..
    The requirements that make it all easy is that both of the computers, the radio and the iPad are on the same subnet of my network and that copy of DAX running on the same machine that is running WSJT to relay audio to and from the radio. My DX Lab Suite logging software uses IP commands over the network to interface the radio. If your logging software requires a serial port to the radio then you would need to run CAT on the logging machine.
    The combinations are endless but the keys to easy are same subnet for everything, DAX if you need audio, CAT if you need radio control.
    Stir in SmartLink & MultiFlex and you can do even more from anywhere.
    Have fun!
  • WK1O
    WK1O Member ✭✭
    Bon,
    Thank you very much for the input. I am running the SDR on the Dell laptop and there is a separate PC for everything else. They are on the same LAN indeed. However, I have not figured out how to interconnect all of this. What are the benefits if any of running SDR and All logging and other soft on a different machine?\
    Alex, WK1O
  • David Decoons, wo2x
    It depends on your needs. When local, I run everything on one PC. SmartSDR for Windows, DAX and CAT do not use a lot of resources. Screen real estate is probably the one reason why you might want to run SmartSDR on a laptop and everything else on a PC. But with monitors relatively inexpensive it may be easier to just add a second monitor to the PC. That way one mouse & keyboard.
    @WK1O
    Hi Alex
    1. Install SmartSDR (the same version) on all the computers you want to use (in this case 2)
    2. On the computer for the User part (you) start SmartSDR as usual
    3. On the 2nd (and 3rd... ) computer start SmartSDR CAT and DAX only. This will allow other programs to communicate with the radio. You can do this with your logging programs, digital programs, etc.
    4. On CAT and DAX, you want them to 'connect' to the correct Station, which is the name of the first PC (or, what ever you set the name to).
    That should get you going.
  • MarkS
    MarkS Member ✭✭
    Mike, Have you done the same thing with a local (at the radio) PC and a remote (distant location) PC?
    I.e. Local PC running the logging program, WSJT, Gridtracker, and the remote running the tuning and voice (when running SSB)?
    Mark - wd9jen.
    with version 3 software it supports MultiFlex with an example - local client running SmartSDR, CAT, DAX and WSJT-X on one frequency while remote station is running another client (SmartSDR Windows, MAC, or IOS, or Maestro), CAT, and logging on SSB
    caveats -
    • 6400 must share same RX antenna. 6600 can be on two different RX antennas.
    • Only one station can transmit at a time
    • you can run full duplex (one transmitting while other is receiving) if you have enough isolation between antennas
    • each station should be running their own profile.
    Probably missing some points but does that answer your question?
    @MarkS
    Yes, I do this daily. MultiFlex is not required.
    Today as an example, the Radio PC is running all the PC programs and I am using SmartSDR for MAC for Audio, VFO control, etc. And, if the operator is remote, he can run SmartSDR on Smartlink. It doesn't matter what the operator client is. Welcome to the network-based radio.
    Dave's solution works as well if you want to get real fancy.
