SmartLink and Apple routers (Airport, Time Capsule, etc)
David Decoons, wo2x
Member, Super Elmer Moderator
I just helped a gentleman running an Apple Time Capsule router (same as Airport Extreme with the built in backup drive).
We found out that the Airport routers do not support uPNP. We needed to use manual port forwarding. Here is a pdf which describes how to add port forwarding to the Apple router.
https://www.rainmachine.com/support/portforwarding/Port-Forwarding-Apple-AirPortExtreme-Router-for-HTTPS.pdf
You only need to add one port forwarding rule to the Apple Airport (or Time Capsule) router.
On page 4 of the PDF it shows how to add the port forwarding.. Here are the setting you need to enter.
Description: SmartLink
Public UDP Ports: 22000
Public TCP Ports: 21000
Private IP Address: <enter the IP address of the radio>
Private UDP Port(s): 4993
Private TCP Port(s): 4994
Click Save button> The router will reboot.
Next go into SmartLink Setup and expand Network Settings. Click Manual and enter the following settings
Click Save then click the test button. You should get a green indicator and if you hover over it (SmartSDR) or click it (Maestro) the bottom section UDP and TCP should show pass.
2
Dave
Why the choice of ports 22000, and 21000 on the WAN side?
On my Time Capsule, I port forwarded WAN side TCP 4994 and WAN side UDP 4993, to the LAN side TCP 4994, and UDP 4993 ports. The SmartLink Test Came back with a green indicator after I rebooted the Time Capsule.
Should I change my WAN side port assignments?73, Jay - NO5J
no, you can leave them as-is. Just what we used.
Dave
Dave
Thanks for the quick reply! I had no particular reason to setup the 1 to 1 pairings I used, and thought I might have overlooked something important.73, Jay - NO5J
I think you also need to enable NAT-PMP also.....0
It was already enabled. Check the pdf article I lonked to in the above posting. Page 4 I believe. Dave0
You might want to do a DHCP reservation too.0
That I dd early on, setting static address for a number different devices.
Dave - Thanks for posting this, it instantly enabled smartlink for me on my apple airport extreme. I was starting to think it was going to be very complicated but this worked perfectly and was super easy to follow. Thanks again!!!!!0
Glad it helped! Dave wo2x
I'm a new Flex6600 owner and have an Airport Express....this worked great. Thanks Much - Tony W4TYB0
You are welcome. Glad it was useful. 73 Dave wo2x0
Just tried this configuration tonight and it worked perfectly! Thank you0
You are welcome!
Dave. I have an Apple Airport Time Capsule router. It's so old it really should be replaced but that's another discussion. Thanks for posting this very helpful discussion.
Got it working!!
Dean0 -
Glad it helped Dean. I have upgraded to an Eero mesh system.
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
