Tuner Genius Auto Sweep Node-Red Application
Dave, WO2X and I have built a Node-Red based flow to "Teach" the Tuner Genius frequency solutions across a selected band and selected increments. Here is a video Dave made on its use.
Learn more by visiting the Ham Radio Node-Red IO group.
Here is a link and discussion for a "Stand Alone" version.....only includes the Tuner Sweep Node-Red flow:
Here are Links to the same Tuner Sweep, but also includes integrations with the WO2X Tuner Genius and the Flex Radio Node-Red Flows:
Alan. WA9WUD
I want to thank Alan and Dave (and Kyle) who do a LOT of NodeRed messing around.
What is cool is that you don't have to program at their level to customize something simple that works for you.
Does this and other Node-Red apps work natively on MacOS? Thank you, dan
Dan
Yes, Node-Red can run on a Mac.
https://www.youtube.com/watch?v=9cHxLJq30AI
I would be happy to help you set it up if you like.
send me an e-mail to coordinate.
Alan. WA9WUD. a.alan.blind@gmail.com
Alan Thank you. Install video was good and straight forward. Thank you. dan WA1QZX
I added a Sweep Memory Module to the Tuner Sweep Flow. Dave, WO2X, is adding the same to his integrated set of flows, containing the same.
Here is an example of using the Tuner Sweep Memory Module.
I swept my G5RV on 80M, 40M and 20M. One sweep each with the Tuner in Bypass and another with the Tuner In Circuit. I stored each result in memory for future reference. Here is a screenshot of the Drop Down menu showing the stored Tuner Sweeps.
Alan. WA9WUD
Where can I get this and will this work as a stand alone for a non-flex radio?
You can use part of it for standalone, but the bypass and unable to find match part will not work. It is designed to communicate via API with the Flex 6000 series radio, Power Genius amp, and Tuner Genius.
You are welcome to use it and edit as needed to work with other equipment.
W2NER
I have an SWR sweep flow set up to interface with other radios. Auto-tune, but it will sweep the band and give you a bar chart at each frequency.
To use this, you need to have set up a Node-Red interface to your rig, so you can command a "Tune" and receive the SWR measurement.
If you have this connectionism and understand Node-Red basics, you can make this work. Here is a link to download the SWR Sweep Node-Red Flow. Download the SWR sweep file at the bottom of the list.
Alan. WA9WUD
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 767 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
