Keying Amp Without PTT
Is there a way to use my Acom 1500 amplifier and the Flex 6400M while remote? Amplifier is a tube type so it would look something like this---- I would like the radio to key the amp without using the amp ptt. The amp would be set and tuned to a set frequency so no frequency or band changes would be needed. Basically, I would like to chat with a AM group down in my shop using the laptop and of course the radio and amp are located in the house.
Regards
Larry
Yes, just hook up your Amplifier normally.
You can disable Amp PTT in your TX Band settings. So that when you go to 80M it is active.
Thanks Mike,
Will need the amp to key when I click the mox button in the software.
I remember the old CB amps I think were rf sensing to key the amp?
Larry,
RCA cable from TX1 on radio to amp PTT in. Check the TX1 box in TX Band Settings table for each band where the amp will operate. Now when the radio goes into TX (MOX, PTT In, etc) TX1 out will key amp.
A few precautionary things.
- set radio maximum power out to the highest drive power you will need on any band. Protects against accidental overdrive of amp.
- have a way to turn amp on & off remotely and operate/standby.
- use a wattmeter that can be accessed remotely to verify power and SWR. Some meters can have the PTT line to amp looped through them to open amp PTT during high SWR conditions.
CB Amps had RF sending keying lines since it was illegal to have an Amp on a CB radio and hence the reason there was no PTT keying line.
What @David Decoons, wo2x says is absolute gold. At minimum I would get an Elecraft W2 watt meter or al LP100 watt meter that can break the PTT keying circuit for key SWR issues.
What you want to do is a bit risky for a remote since you can't touch up the antenna tuning if required on the amplifier.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
