multi-nated home network issue
Chuck
Double NAT is a show stopper for SmartLink.
Others are using VPNs, such as Open VPN and thus bypassing the need for SmartLink, but.....with mixed performance results. Do a search on this site to find many posts on using VPNs.
Alan. WA9WUD
If your ISP is not CGNAT and your house is double NAT'd you can make it work.
If it was my place, I would take the 2nd router (the router beside the router) and put it in bridge mode. That will solve your issue.
If you can't for some reason, you need to do port forwards from the main router to the 2nd router and then another set of port forwards to the radio.
You may have to bring in someone more knowledgeable to do this for you if that didn't make sense.
[{"insert":"thank all ,maybe i need change my ISP\n"}]0
Before you change, take some time to understand their network first. If they are not CGNAT, then you control everything else to make it work.
hi guys,i have changed my isp, everything gets ok yet, thank you all,730
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
