"Clean Sweep" of Windows 10; Install 3.3.32 directly?
I had 3.2.39 on my PC but had a problem for which I sent the radio in to FLexRadio for repair. The radio should arrive at my home tomorrow (a day early). The suspicions of both the Flex tech and now me is the problem was likely caused by the PC. Since sending the radio in for repair, I noticed some other problems with Windows 10 (Pro 64-bit), so I did a complete clearing of the (C: drive) SSD and reinstalled Win 10 and now all is OK (so far... like a whole new computer). I have yet to install any SmartSDR software, but am considering the following:.
Considering the radio still has 3.2.39 firmware, should I first install that software on the PC and then do the update to 3.3.39, or just install 3.3.39 and let the radio update its firmware? I saw something in the Release Notes about how it make take more time without 3.2.39 installed, but this is a clean installation on the PC, and time is barely an issue and not a problem for me. In other words, is 3.2.39 required to be in place prior to 3.3.39 is installed following a clean installation of Windows? Either way, I plan to not import any profiles, but rather will build a new profile after the software is up and running in its basic form.
If you think there is something in 3.3 that makes you want to swap to it, I would do it direct. Never installing a previous version (Since you have the .net update already with 3.2.39)
If you're Mostly CW I'd probably go with 3.3.
If you're a primarily Phone / Digital I'd stick with 3.2 for now.
Ron, WV4P
Rather than ask here, I would recommend you defer back to Ken or Tim and ask them what they recommend. They have worked on thousands of cases and they can give you good direction.
They know what works and what doesn't make any difference.
Mike - I left a message for Tim.
Thank you.
Update: The radio arrived this afternoon and I set it up "from scratch", including directly installing v3.3.39 software/firmware. The entire process finished in relatively short order with no problems whatsoever.
So far, so good; everything is working.
Now to go play radio. :)
A lot to learn and a pleasure to operate.
- 634 The Flea Market
- 131 SmartSDR+
- 198 DAX
- 42 Aurora
- 955 Maestro
