Flex SWR Sweep for Node Red
I built a Node-Red based flow to scan a range of frequencies.
The Flow will work, stand alone, with any Flex 6000 series radio. The Flow will use Flex Slice (0) as the scan RF Source.
Here is a screenshot of the final scan I did on my G5RV on 20M:
For more information and a link to download the flow, go to the discussion I started on the Ham Radio Node-Red IO group:
Alan. WA9WUD
I found a good use for my Flex SWR Sweep Flow.
I have a TX-XL. Here is a "as found" sweep on 40M of my G5RV antenna:
I then "taught" the TG-XL the tune solutions for the higher SWR values. Here is the new SWR Sweep. Note, I forgot to teach the tuner 7.24 MHZ (note, the different "X" scales for each data plot).
And here is the same antenna, with the TG-XL in "Bypass":
My next project is to build a flow to use the same sequencer, but to command the TG-XL to learn the best tune solution, for any antenna, across the band.
Alan. WA9WUD
Thanks Alan for your contributions.
I will have to give this a try!
I finished building the Tuner Genius Sweep (Teach) Node-Red Flow.
For more information, and to download the flow, here is my posing of same to the Ham Radio Node-Red IO Group:
Here is a screenshot of the Tuner Genius "Learning" the tune solutions for my G5RV antenna, 40M, 10 steps:
Alan. WA9WUD
I've been tweaking Alan's fine work. Now integrated in Node Red to my Flex Radio and Tuner Genius flows.
I've also been tweaking color scheme to make it more readable with text yellow on black and the SWR bars above the frequency and tuner values. The SWR numbers at bottom were changed to white on black.
The fun with Node Red is you can customize it to your liking!
P.S. - Alan and I like to team up :-)
73 Dave wo2x
Looks good, Dave.
The visual display reveals all aspects of your G5RV antenna characteristics and Tune solutions. The resonate portions of the G5RV are easy to spot.
Also, very easy now, to re-teach the Tuner Genius any Band/Antenna configuration, especially when the seasons change and the antenna characteristics may also change.
Alan. WA9WUD
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 181 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
