Proper way to constrain PGXL transmit power output
Best Answers
Not today, however, you. might be able to come up with a NodeRed solution.
John's point is accurate in that an increase from 100 watts to 300 watts will not really be noticeable by the receiving station.
A great experiment is to get on the air with someone and very your power from 100 to 300 and see if they really notice the difference. I had an Elmer make me do this and it wasn't until after that I really appreciated the physics of RF power.
A couple of comments.
Use the TX band setting table to set power out per band for use with the amp.
In FRStack if you set the field "When PG XL mode is Operate remember radio power and limit maximum radio power" and set that to zero. THat will use the TX band data for power setting. It defaults to 50. If left at default it will set power out to 50 every time you complete a tune cycle on TG XL.
73 Dave wo2x
Maybe just bypass the amp? Boosting a 100 watt transmitter to 300 watts is barely a one half s unit increase, no one will notice.
Thanks Mike & John. I'm brand-new to the PGXL (and amps in general) so I now understand the only way to vary the transmit power of the amp is to just vary the output power of the connected Flex6400 via the RF Power slider in SmartSDR.
I was originally thinking I had to set the output power of the Flex6400 to a constant value (somewhere between 1-100) and then somehow adjust the transmit power on the PGXL, but that's not the case.
Ron / K4XRF1 -
FRSTACK has a power level setting for PGXL in Operate then goes back to 100 watts on standby, but not for a particular antenna.
Hi Ron
I use Global profiles. I set up one for each mode ... FT8, RTTY, CW and SSB. I then set many of the parameters for each mode that I want such as tune power and RF power ... per band and save the profile. that way you can set the power per band.
as far as running power with the PGXL I have noticed a difference in being able to making contacts with as little a 200 watts from the PGXL ... doubling the power is only 3 db but every db counts in poor conditions ... but of course your mileage may vary
good luck the PGXL is awesome
73, Ian VE3JI
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
