RF Sense
I am trying to get my Yaesu FTdx10 setup as my backup radio and I am trying to get it to work with the Tuner Genius XL. I am using the same antennas as I use with my 6700 but when I transmit with the Yaesu, I get a "No PTT IN" alarm on the tuner genius. I thought the TG could RF Sense? I see RF SENSE on the front display but I'm not sure how it works.
You still need to set up a PTT or the TGXL will not go into TX mode.
RF Sense is for frequency detection.
I have a Ten-Tec Eagle that I would like to use with the TGXL. Since I can't use CAT/CI-V that leaves the FlexRadio as my option as indicated above. So when I switch radios this means i have to go into the TGXL control panel and change the PTT source. What about the the serial number? I find this approach rather strange and actually more work than it is worth. I would think that the tuner should be able to take whatever input you provide. I am using the 1x3 tuner.
Don - kx9q
Since there can be multiple Flex radios and multiple TG XLs on same network, and PTT from Flex is via LAN, it needs a way to determine specific Flex.
I understand what you are saying, however, I also have a flex 1500 along with the Ten-Tec Eagle and the question is how am I able to utilize the TGXL with the 1500 and the Eagle? Do I have to plug and unplug various radios to the TGXXL in order to use the TGXL? If so that will defeat the use of the TGXL with non flex or older flex radios by making it cumbersome using the TGXL.
Don - kx9q
Well, the TG XL needs to see PTT from the radio (whichever you use).
W2IHY makes the iPlus which switches speakers, mic, and PTT out from multiple radios. You could look into something like that.
Thank you for the info on the W2IHY iPlus. Out of curiosity I noticed the TGXL has a PTT In and PTT out (1x3 TGXL). So can I run a cable from the PTT out on the TGGXL to the PTT in on the PGXL? That way I would only need one PTT cable from the radio to control the TGXL and PGXL. I also noticed the PGXL has a PTT in and PTT out. Not sure why I would need a PTT out on the PGXL.
Don
Hi Don,
the PTT delta that needs to be set in the radio needs to cover the tuner PTT and amp PTT. If the radio cannot be adjusted with enough TX delay then you can have your PTT switch go to the tuner, then tuner to amp, then amp to radio. That makes sure tuner and amp are in tx before RF is applied.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
