Tuner genius XL displays RF power low on some bands, when tune button pressed.
Please tell me what I'm doing wrong.
Thanks David WA6TWF
This usually meens your tune power slider in smartsdr is to low, you need about 20 watts of tune power to tune it.
Thanks, but I have tried putting the power all the up and still the display on the turner says RF power low.0
I assume you have the latest firmware 1.1.8 for the TGXL?
Mike.
[{"insert":"Thanks, but I have tried putting the power all the up and still the display on the turner says RF power low.\n\n"}]0
Yes we are using 1.1.8 firmware for the TGXL.0
PROBLEM SOLVED. Its the tune power that needed to be increased. Not RF power.
Thanks to Dan at help desk.0 -
I wish all things in life were that easy!
glad you have it sorted👍
73 Mike
The display should say tune power low not RF power low.0
Thanks guys for all the help.
David WA6TWF0 -
It looks as though the first answer by Larry _ NY8T was correct.
YES Larry was correct. Since the display said LOW RF POWER I THOUGHT IT MENT RF POWER.
My mistake. I learned a lesson. Read the reply more closely.
David, yes, I understand your confusion but the "Tune" slider does set the RF Power in tune mode. So the display was correct.
I sometimes take things too literally as well...
I'm glad you got it sorted out!
Thanks Geoff
David
Reason it does not say Tune Power is the tuner can be used with other radios where there is only one power out adjustment.
Glad it is working for you.
73 Dave wo2x
Thanks for all you help guys.
David
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
