Best Equalization for PR40 & FlexRadio 6600 ??
this is what I'm trying
PR40 v1.0 1,-3,-7,-2,2,8,10,10
Mic gain 80
Adjust Vox Delay Settings DX
Got a good report from a friend....however he said was not as good as I usually used to do with my 6300
Any Advice?
Equalization? New Mic?
Best Regards
George, YV5WZ / PY3ZZZ
George, W8NVC in Parma, Ohio. use your monitor with headphones and get it to where you like it. Then go to www.websdr.org. find the remote in Pa, set the screen for ssb and make sure you set the rx width for what your transmitting at. Listen and you can record on this site. do a recording, then download it and listen again with headphones, keep that up until you get it just right. Now keep this in mind, The Pr-40 has a lot of bottom end and I like that but that's me, get it to where you like it and leave it. Do some comparisons and you will find your sweet spot and your done. This is better than listening to one guy say it sounds good and the others saying something else. A lot of times it's the band, Just make sure your ALC don't exceed 1 db. most us 0 db but with the pr 40 I would stay at 0 to 1 db. good luck.. 73 from Nick W8NVC Parma Hts Ohio.2
I would have thought your old EQ setting would be the same for the 6300 and the 6600. Comparison of mikes especially between days can be misleading. I have used the same mike, same radio, same settings from day to day and reports of quality are different even from the same individual.2
When setting up new microphone on Flex 6000 series I recommend Ken Wells NM9P you tube video
https://www.youtube.com/watch?v=LytzQGpE5ZM
I set my TX audio up with it couple years back and have not touched it.2 -
Thank you!!!
I makes little sense listening to your audio from another station hundreds of mile away. Simply record your audio and listen,,or as Dan said above use Kens method. See his Utube video.0
Don't buy a new mic. The PR40 is terrific. I experimented with the settings of other mics and found a couple that were outstanding. Make sure the bias if OFF (Radio setup - TX). When you find a mic profile you like and have tailored it like you like it, simply rename it.
Here are my TX Equalizer settings for MY Voice and MY PR40 that may help you out.
If you can find another FLEX operator that you can easily talk to and have him check and record your audio.
No one sounds like them selves hearing there own voice, it is really best to have someone who knows your voice listen and try to get the best audio that is has good mid range and not a lot of base.
In "settings" / "Radio Setup" / "TX" ENABLE "Show TX in Waterfall" on Your Transmit Spectrum display should be FLAT as possible and the Waterfall colors should show where your audio peaks are USING NORMAL speech (Say "The quick Brown fox jumped over the lazy dog") to see on your display what I'm talking about. Don't just say 444444444 or whistle into the MIC that wont give you a good indication of how your audio looks and of course sounds.
You can see from the picture below most of my base is being taken out by the EQ because that is a HUGE waist of Power down where no one can hear that low but increased in the area that fits most people can hear easily.
ALL VOICES are different so my settings will be different then yours for the PR40 BUT this is what works for me after a lot of messaging and my good friend just a couple miles away helped me find MY EQ sweet SPOT.
This provides excellent Audio reports and really packs a punch.
Processor is set to DX, MIC Gain set at 77 with the MIC plugged into the Balanced jack on either the 6700 or 6600M.
Interesting almost the exact setting for my Heil 781. But Bob Heil did tell me that he has only a few elements that are used in all his microphones so no real surprise here.
My settings are very similar to the above. My only caution is the boost at 4K. If the transmit bandwidth is limited to 3000 hz or so, the boost isn’t helping much and could be causing some distortion/artifacts. Most voice intelligibility frequencies are in the range of 300 to 3000 hz.
Make sure you use the Full Duplex feature of the radio to listen to yourself.
That way, you can tailor it for your liking, not someone else's
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 174 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 881 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 735 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
