v3.3.32 Did Not Address Audio Stutters/Sputters Regression from v3.3.29
The issue described in post "v3.3.29 Audio Stutters/Sputters with Several RX Slices" which is a severe bug introduced with v3.3.29 was not even addressed in this "maintenance release".
I and others created tickets for this issue after v3.3.29 was released and were told by Flex they had confirmed it was a regression in v3.3.29.
This bug literally prevents me from using my radio as desired; as I have for years.
When are you going to fix this regression Flex ? No "marketing responses" please.
Russ Ravella, KR6W
    Russ
    Can you describe your operational setup for this failure please.
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    As I mentioned in my post, I (and others) have already submitted a ticket for this and it's already been identified as a regression in v3.3.29 so describing my "operational setup" again here is clearly irrelevant. I'm simply asking when Flex is going to fix it.
    I am reviewing your case and I see you haven't tried 3.3.32 which was just released, so you might want to give it a try.
  • Russ Ravella
    Please read the title of this post.
  • Dave S
    Dave S Member ✭✭
    This is too funny
