v3.3.32 Did Not Address Audio Stutters/Sputters Regression from v3.3.29
The issue described in post "v3.3.29 Audio Stutters/Sputters with Several RX Slices" which is a severe bug introduced with v3.3.29 was not even addressed in this "maintenance release".
I and others created tickets for this issue after v3.3.29 was released and were told by Flex they had confirmed it was a regression in v3.3.29.
This bug literally prevents me from using my radio as desired; as I have for years.
When are you going to fix this regression Flex ? No "marketing responses" please.
Russ Ravella, KR6W
Russ
Can you describe your operational setup for this failure please.
As I mentioned in my post, I (and others) have already submitted a ticket for this and it's already been identified as a regression in v3.3.29 so describing my "operational setup" again here is clearly irrelevant. I'm simply asking when Flex is going to fix it.
I am reviewing your case and I see you haven't tried 3.3.32 which was just released, so you might want to give it a try.
Please read the title of this post.
This is too funny
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
