6600M Display - Very Disappointed
I've had my 6600M for almost 9 months now and the display is a real disappointment ... Things started out okay ... Now, most times it comes up trash and can barely read it ... Thankfully the radio is behind a wall in my shack so I don't see it ... But for the price point you'd think it would have lasted a bit longer??? ... Lesson learned ... I should have bought the non-M model and saved myself a bunch of money ...
Steve / W1SMC
Have you opened a help desk ticket with Flex? After 4.5 years of almost daily use, my 6600M display still looks great.
Also 6600M. No complaints here, either. Great screen👌
I've had my 6600M for almost 4 years of daily use with no display panel issues.
Hi Steve... as Neil said, I would HIGHLY recommend opening up a Help Desk ticket. Flex are very responsive. While they do have reps that regularly check this Community, your best bet is the HD ticket route.
As others have said, a wonky display on an M model is not normal behaviour.
When you say '... it comes up trash...' can you provide more detail? Is the screen blank, unreadable? Can you take a picture with your phone and post it? Most of us won't have the tech background to help you with this, but it will sure help the techs @ Flex.
The display comes up cloudy with many white horizontal lines and some vertical on the left side. Also, sometimes after 15 or 20 minutes things do clear up some ... Currently the rig has been running over 6 hours and the left side of the display has some vertical white lines and they are blinking ... When I first start the radio though the display looks like a mess ... And it's not because I have yet to take the plastic covering off ... Hi Hi ...
I would contact the Help Desk and get an RMA ticket started. This definitely not normal.
Like the others here, I have had my 6600M since they were first available. And I have never had an issue like this.
I agree.. I see multiple 'hardware' problems here. There is definitely a fault in the screen and/or its drivers/connection.
This is a hardware issue and needs to be resolved by our support team.
Please open a support ticket.
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
