3.3.29 DAX - can't control RX 1 audio level vs. WSJT-X
I upgraded to SmartSDR 3.3.29. Since then, WSJT-X receive bar is +80dB red. When I go into windows 10 sounds, and look at DAX RX devices, there are two different sets in RECORD with the same names (DAX audio RX 1) but different icons., and also a SET of DAX audio RX 1 thru 8 in PLAYBACK area. None of the ones labeled "DAX Audio RX 1" will control the actual RX level for the WSJT-X receive bar. Neither will the RX gain slider on the SmartSDR DAX desktop window, in the RX Streams 1 window section. Did the 3.3.29 installer corrupt the DAX RX and TX devices? WSJT-X is working and decoding, but I simply can't control that RX level going into WSJT-X.
Thanks for any help.
Neal, N6YFM
You might have to open a support ticket for this one Neal. DAX needs some TLC it seems.
Mine did this and I simply went to DAX window clicked of the RX button for the slice I was on and disabled it then reenabled it and all was good here.
Hi Neal
If you need an extra set of eyes to look at the problem, reach out to me direct. My e-mail is good on QRZ.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
