What size is the SD card in 6600M which had the PEN update?
First question is what size SD card is in the 6600M?
Second, my 6600M underwent the PEN update when it was first announce.
i was wondering if it received an updated SD card at that time?
Paul K3SF
Best Answers
hi Mike...
egads :=)
... i am not sure where i put that ticket and paper work as it has been quite a few years (~5) since it was done.
i did send the 6600m back to Flex to do the actual PEN update... yeas ago
I have No problem with the 6600m even the update to 3.3.29 went well.
EXCEPT
When I did the update to 3.3.29 i had to revert back to 3.2.39 because my Mac s/w doesnt work properly with the update. I did file a trouble ticket and was advised to contact the mac s/w developers and then the trouble ticket was closed. I did contact Marcus developer of SSDR for Mac and was advised by him to hold off on doing the update to 3.3.29 as he was working the problem. The other mac s/w is xdax and xcat by Mario.
i have not contacted him yet.
Also know Flex is working an ATU issue with the update so i will wait till that fix and Marcus's update too.I
I asked the question so as to get a headsup if i should anticipate SD issue next time I try the update.
No trying to cause any trouble , just trying to get some info so i can make an informed decision.
Paul K3SF
The card is a 4G card, at least anything past about 2019 should be. (don't 100% quote me on that).
You are ok to go forward and backward, so that shouldn't be a big issue. I do know that the developer of DogPark SDR had to make some changes with V3.3.
No worries. Always good to ask questions.
You can look it up on your support ticket and if the card was replaced it would say so.
Hi mike
I was able to find my email for the PEN and contacted FLex. The response i received from Ken Wells at Flex was no SD replacement was shown fro the PEN and based on the age of my 6600m it has the 256Mb SD.
So it sounds like it might be a good idea to replace the SD before failure hits with the current 256Mg SD
Any advice on how to do this would be helpful
Paul K3SF
If it was me, I would just do the update. If it fails, we replace it for free and you get it in a few days. I would not do the update today since it might leave you without a radio all weekend, but do it Sunday night or Monday morning.
well, i opened up the 6600m...
yep has 256mb SD...
has been put back in and booted up fine...
Oh ..while i have it open. i cleaned up the fan. and rest of the radio
not much dust at all
and
made sure the ether net cable from the front panel was tightly set since i was cleaning the fans and bumped it...
will try later this after noon for the update and see how all that goes
depends on social calendar how much 'free me time ' i actually have ;-)
Paul K3SF
Thanks for the great picture. :)
We find that some people have a challenge getting the card in the correct place and then sliding the retaining clip back so that it locks in. It does take a bit of careful attention.
hi all
ran the update this afternoon with this 256Mb SD.
all went well...
even got it working with my Mac s/w like Mac ssdr by Marcus
and xdax/xcat by Mario
and
running wsjtx native mac from main panel of 6600m
and
also with macssdr with four slice using xdax/xcat interface
and
with four instances of wsjtx
Paul K3SF
UPDATE 12 May2022
I had ordered the 4GB SD as my 256Mb SD didnt fail just needed to be reseated
but i wanted my 6600m to be totally up to date.
the 4Gb SD arrived today from Flex
took about 2 minutes to install as i had already the case top off when i reseated the 256Mb SD
the 4Gb SD came with 3.3.29 on it...
The 6600m came right up and all my mac s/w working fine ( mldx, mac ssdr, xdax, xcat, wsjtx, fldigi)
OH...did have to rebuild my profiles but i am getting good at that...
Paul K3SF
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
