Strange MOX behavior
Any ideas?
If the MOX engages, then something else commanding it.
Is there any other application connected from the radio?
Any chance the VOX is turned on? If you have confirmed that it is none of the above, I would do a radio reset after saving your profiles first.
If that doesn't work, it would be a good idea to open a support ticket to pursue further.
Hi Robert, You don't have VOX activated do you? Is transmit DAX selected?
If not, try disconnecting the mic and PTT connections to see if if still happens. Just want to eliminate the possibility that it is a physical PTT switch issue.
If the VOX and DAX are off and the mic/PTT are disconnected and you still get the behavior, try a factory reset after exporting your profiles.
If it still happens, it is probably time to submit a help desk ticket.
VOX is not on, DAX was off. I will run the rif today with the Mic and PTT disconnected. Thanks for the help.0
It looks as though the Mic/PTT was the problem. Many thanks for the help!0
Glad I could help!
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
