V3.3.29 update unsuccessful on Flex 6500
I attempted to update from 3.2.39 to 3.3.29. The process began normally. After about ten minutes, the update progress bar stayed yellow and progressed from left to right and never changed state and the red light on the 6500 flashes and TIMEOUT is displayed on the 6500.
Bob, KN4HH
Additional information. I shut down the radio and re powered radio and now it will not complete the calibration cycle.
I had the same problem with my 6500 and they're sending me a new sd card.. So looks like the 7610 will get an outing until its fixed
Thanks for the info. I am awaiting a reply from my Help Desk Ticket.
Bernard G0AJZ ,Flex 6500.
Also have the same problem after download attempt,
Rig Shows three red flashing lights and display says timeout.0 -
Just opened myself a ticket. Lost my 6300 to the update.
Now, it's just a matter of hoping and waiting.
Santiago, HI8O
I have the same experience as did Bernard. Radio is 6300.
Mike, KB4HIN
I just tried to do my 6600 - everything seemed to update just fine - I powered down the radio and cold booted - now I am unable to connect to it from Windows or Mac - it connects for about 1second and then disconnects and I get red flashing power button. Going to open a ticket.
my 6500 is bricked with this 'update'....k5lc tells me his 6700 is also....same thing
'timeout' and red led blinks 3 times....1st time an update has ever killed my radio...
totally unimpressive....w5xz, dan
So I was able to revive my 6600 - after several crashes/reboots - I hard reset the radio - rebooted the PC and was able to attached and get back online. Its working great now. (it was the 2nd hard reset I did)
I have the same issue with my Flex. It shows "Timeout" after "Calibrating...". Reboot did not help. I already opened a tickt. It is the first time I have issues with a SW upgrade.
None of the beta testers had this problem??
How is it possible that so many of you are experiencing update issues.
Nobody from so called Alfa Team has had this issue?
Is this an issue with the 6300, 6500, & 6700 or are the newer 6400 and 6600 also effected?
This certainly isn't the 1st time Flex has update issues.
Please Posts any fixes either from Flex Radio or User discovered.
It depends on the age of the radio and whether or not it has the original SD card in it. If the SD card has been replaced at some point, it looks like there won't be any problems updating except for the ATU problem. That isn't related to the SD card corruption issue.
I would suggest that people hold off on this update even if they have a newer SD card in their radio. More so, if they use the internal ATU. It seems like someone dropped the ball and didn't test this update enough. ( regarding the ATU problem) SD card failures, Flex Radio has known about for a long time now. But, instead of being proactive and replacing them BEFORE something like this happens, they decided to wait and replace them with more durable SD cards as they failed. They brought this on themselves by not being proactive. Not a good thing.
Remember the ALPHA and BETA testers get MANY updates to try before they send it out to us lowly users in a release version and may or may not have gotten a NEW SDCard to use before in their checking and fixing features.
I think this all depends if your radio ran a earlier version of SmartSDR that had the SDCard corruption in it and it is a hold over from those even though you had no issues with 3.2.39.
This is a NEW animal now that I think actually re-writes the SDCard and not just replace the necessary files and somethings going on with the older radios SDCard's that ran earlier BROKEN versions of SmartSDR won't let the full update run.
With the 6700 and 6500 that have a RADIO display it shows a "Timeout" error, On the OLDER 6300 it shows a Blinking RED LED, On the 6600M it shows that there is NO network connectivity on the Bottom Left of the Maestro front display and continues tries to reboot.
After Watching this very closely on my 6700 and 6300 and my Friends 6600M I think what happens to crash the update is on one of the Reboots it doesn't let the Network connection come back on and establish the Computer OR Maestro control head connection to totally finish the Update.
That's my opinion anyway.
In my case, I found one way to "fix" a corrupted SD card is to write a new version of the firmware to the card. I have done this by downgrading and then upgrading the firmware.
This technique does not work if the corruption is so bad that the Flex will not boot up. I first noticed problems with profiles and unexplained Flex shutting down. Doing a downgrade/upgrade always fixed the problem, before it progressed to a failure to boot (three red flashing lights).
Since Beta testers re-write the SD Card OS, with each beta version, their SD cards are "repaired" if there is any corruption on each beta test SD card OS re-write.
Just my theory.
Alan. WA9WUD
Update went well on my 6400m, but, My Icom PW 1 does not like it when I touch the tune button on the radio.
Sometimes ok next time Red amp protect light lights.
No rhyme nor reason when it will happen?
Overshoot on drive power?
Still set well below limit?
Reinstalled previous version and appears ok now?
John/W8JER0 -
Hi John, That doesn't sound normal. I would submit a helpdesk ticket.
Same problem with my 6300. Update from 3.2.39 to 3.3.29 failed; radio flashes three red lights and repeats.
Dave, KC2MB0 -
My 6700 has been flawless until this update so my SD card was an original. I opened a ticket shortly after getting the Timeout- 3 red flashes, and was very promptly attended to. Hats off to the support team, Ken and Tim who quickly determined the issue and sent me a new SD card to Canada and I received it yesterday morning and did the swap out last night. All is fine again in my Flex universe. I decided not to import the old profiles and start a new.
3 -
WX7Y
Quote== ""After Watching this very closely on my 6700 and 6300 and my Friends 6600M I think what happens to crash the update is on one of the Reboots it doesn't let the Network connection come back on and establish the Computer OR Maestro control head connection to totally finish the Update."""
On to something maybe turn off Static before the update in radio setup.
My 6700 just self-detonated after the 3.3.29 update with the "TIMEOUT" error. This is the second time an update
has crippled my radio. Way to go Flex!
-2 -
Another one bites the dust. Open a help desk ticket. You're gonna need a new SD card.
6500- Successfully upgraded from 2.7.6 direct to 3.3.29 less than 8 minutes.
Using windows 11 and I turned off Malwarebytes made sure computer was all up to date.
I did not un-install anything just went right to the 3.3.29 install.
Still had all my settings from 2.7.6
Oct-2014 6500 model...
======================================VVVVVVVVVVVVVV====================
I missed this one. Explains it all. I vaguely remember the processor issue.
I am now new user of multiflex. Ipad works great as well as desktop at the same time.
Only a few hours but haven't noticed anything bad.
Just curious if anyone else has had this problem with v3.3.29 and a 6500 when updating from v3.2.39.
The firmware load stalls with yellow bar all the way accross the display. Powering off the radio and doing a cold boot and then starting SmartSDR v3.3.29 connects to radio okay with radio and ATU appear to be working, but DAX and CAT cannot find radio without a dropdown selection available to select a radio.
Downgrading to v3.2.39 also stalls at the end of upgrade, but all works.
There is a ticket in work, but has not been solved yet. Just checking if I am the only one with this problem.
Just bricked my Flex 6300 going to 3.3.29 Wasn't aware of the problem until after it happened and I was googling for a resolution and found this discussion. I've opened a help desk ticket as per instructions above, I'll let ya'll know the outcome. I would think Flex would email out a warning as this has been going on for several months based on dates of comments.0
All that comes to mind is this.......
My 6500 is dead in the water during the upgrade from v2 to 3.3.29. Towards the end of the upgrade, the calibration stayed on until the lights flashed 3 times and timeout. Now I can not even get the old version to come up. Dead in the water.0
Corrupted SD Card you have to open a Help ticket and Flex will send you out a new one. It's not a tough install if you are handy otherwise back to Flex it goes.
Best of Luck
Ian
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
