Where is the SD card located on the flex6500?
Does anyone know the location of the SD card? Have both top and bottom covers off. SD card not visible
Best Answers
@kt4xn - Please open a support ticket if you need a new SD card.
Do not take a copy of someone else's SD card and insert it into your radio. You won't like the outcome. :)
It's inside the CPU (large) Faraday cage on the bottom PCB.
How do you get this cover back on after replacing the sd card? the instructions do not cover this issue. The chassis overhang does not let you align the tabs that are under it.
Gene K1GD
The opposite way you took it off just reverse the order, Don't rush it, If it is all lined up correctly just start the side that is hard to get to first making sure the tabs are all lined up, you can see this from the under side of the cover if you have it at 45* angle then carefully and slowly push down away from the starting point making sure the tabs all line up as you go left to right and forward until all the tabs are in the right spot then just push down on the cover around the edges making sure that every other tab is in and the others are out.
Use a jewelers small screwdriver to properly position the tabs and make double sure all the tabs are correct.
I would use a little peace of scotch tape to secure the lid because the Warrantee stickers will not stay down once removed for access.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
