Issues with 3.3.29 Upgrade?? --- read me
UGHH just did the upgrade from 3.2.39 to 3.3.29. Saw the SmartSDR sending the upgrade to the 6500. Now the 6500 does recal, the dots and then timeout. I tried the ON button and Power button fix and same time thing, I get flashing white with calibrating and dots til TIMEOUT.
I got around the remote connect issue I had before, that's fixed so this is not related.
I am connected with PC to same hub as the 6500 on ethernet.
Help please.
I am getting Timeout and 3 red flashes. I have submitted a HelpDesk ticket, but is there a fix yet? I havent rebooted it yet myself, until I know what to do
I should update - same as you Wayne, yes three red flashes, then another three, then....
If you are having an issue, please open a support ticket as it really isn't of value to debug in the community.
For timeout issues, follow the instructions in the readme regarding rebooting the radio.
If that doesn't resolve your issue, please open a support ticket as it will be the best use of your time and get you going in the right direction ASAP.
I will likely also delete any conversations in the community unless there is a reason to share and it might be a worth while conversation.
I am closing this discussion just so we can focus in the correct direction. (it isn't personal) :)
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
