Flex 6600 and 10 Meters
Lewis Mead
When I change bands to 10 meters, the radio totally locks up. I have to restart. Happens every time. Tried re-installing SMART SDR 3.2.39 to no avail. Need advise please.
Best Answers
Hi Lewis, That is not normal behavior. The first thing to try is a factory reset. Be sure to export your profiles first.
If that does not fix the issue, I would submit a help desk ticket.
I would suggest resetting the radio after you back up your profiles. Yours is a somewhat unique issue, so that is why I recommend giving it a shot.
When you change bands or when you transmit on 10M?
How are you changing bands? With logging software or by changing bands with SmartSDR? ios? Maestro?
What model of radio?
I'll need you to describe a bit more of your operating setup.
Thanks for the help. When I am changing bands with Smart SDR, meanwhile, I sometimes operate remote on my iPad and it changes to 10 meters with out issue0
I did a hard reset and all is back to normal. Thanks for VA3MN and KD0RC!1
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
