Why does the ATU button stay red?
Bryan77
Member ✭
I have a EFLW antenna that is suppose to cover 80-6 M. On all other bands the ATU
functions normally BUT on 80M (CW Area) the ATU goes thru its routine and then the button stays red. I don't normally do SSB in the 80M band as I am running barefoot
on all bands... The radio seems to be trans ok...
Best Answers
It says Red when the ATU can't find a solution.
This can be for many reasons but it is often due to the fact that a solution cannot be found.
You may also find that adding a Mix 31 or 43 choke to your feedline near that radio will help. Do not add any chokes that are closer to 1/4 wavelength from the feed point at the lowest frequency. For 80M this is about 65ft.
This might help https://vu2nsb.com/antenna/wire-antennas/multiband-efhw-antenna/
Yes, he is.
As many find out, End Fed Halfway antennas do require some installation care.
Wow vu2nsb site is a treasure trove of sage information!0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
