6500 and 6400 used with PGXL
Joel Rubincam
I own a 6500 and a 6400. I want to use the 6400 on radio 2 but cant get it connect via LAN. in the setup menu it sees the radio and works fine if i use RCA to key but will work with the lan settings. Anyone have this scenario or have a fix?
Joel NF3R
I know there is a ticket opened but on 6400 (radio 2) are you setting it to Antenna 2 for TX and RX? That must match what you set in amp.
If you are using Ant 1 on radio to amp then in Radio B in amp setup, set it to Ant1.
I opened a support ticket for this.
switched to antenna 2 and it immediately connected. Dave, thank you so much
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
