6500 and 6400 used with PGXL
I own a 6500 and a 6400. I want to use the 6400 on radio 2 but cant get it connect via LAN. in the setup menu it sees the radio and works fine if i use RCA to key but will work with the lan settings. Anyone have this scenario or have a fix?
Joel NF3R
  • David Decoons, wo2x
    Answer ✓
    I know there is a ticket opened but on 6400 (radio 2) are you setting it to Antenna 2 for TX and RX? That must match what you set in amp.
    If you are using Ant 1 on radio to amp then in Radio B in amp setup, set it to Ant1.
    I opened a support ticket for this.
  • Joel Rubincam
    Joel Rubincam Member ✭✭
    switched to antenna 2 and it immediately connected. Dave, thank you so much
